K8061/VM140 | How to install/use the WinUSB drivers?
Hiho,
i bought 2 weeks ago the VM140 board after several good experiences with the K8055/VM110 Board and i’m now definitely confused. After solving the Problem with the LoaderLock he told me that WinUSB is not supported. I allready downloaded the Vistapack and selected the path for the directory i unrared it into for the Installation Assistant. He told me that the Hardware was installed and are now ready to use.
After starting the VB .NET 2005 with my Visual Studio 2008 Professional he upgraded the Sourcecode and i tried as first to check the proper operations of the board. The result was that WinUSB is not supported. Now, after a few hours in this Forum and other websites im more confused than before… so: How to install or use WinUSB for using the VM140 Board?..
Regards
Josh
Maybe there is still the original driver installed for the K8061 in your PC.
You have ro remove this driver.
Unplug and plug the K8061 and install the driver included in the Vistapack
