Is it possible to run this board from usb, using only 5 v analog out. Or are there other parts that require the higher voltage?. What is the maximum current the kit needs, more than 500 ma ?
The analog section (Op-Amps) need 12V. Can’t operate properly using 5V.
The current consumption is less than 500mA.
I have the K8061 card. On both my desktops it works great. When I try to use it on a laptop, I tryed all 3 laptops, I get device cannot start code 10 and windows tells me the device did not work. I have both Vista and XP sp2. Any suggestions? Oh my k8055 card works fine on all computers.
C
You may try the new software and driver.
It is available on the Velleman downloads site.
The file name is:
k8061_vistapack_2007v1.zip
[quote]You can use this software package with Windows XP and Windows Vista.
Code for VB6, VB.NET,VB express edition 2005, Borland C++ builder, Visual C++, VC6, VC2005, Delphi. [/quote]
Yes I installed the new software from the k8061_vistapack_2007v1.zip
and still the same issue. I also tryed connecting it to a powerd hub and still the same issue. Don’t know where to go from here but I really need this card to work on my laptops.
C
Did you install (or update) the new driver from this package.
See the Readme.txt for more details.
Here is a detail of what I have done.
I installed the driver from the cd that came with the kit on XP SP2 on laptop #1. The same way I did it on the desktop. I got an error on the laptop code 10 device cannot start. I then went into device manager and under the group Other Devices the card had a yellow exclamation mark. I did an update driver and installed the driver from the new vista pack. I got the same error now this time the card is showing up under the usb controllers section of the hardware manager same exclamation mark. I then grabbed laptop #2 running Vista, all patched and had the same error this time though when I installed the usb drivers I used the driver from the vista pack. I was able to get both led’s (Power On, USB – 17,18) on the card to work by manually setting the winUSB.sys to start on boot, however when I tried the sample software to connect the software said no card found. My settings are a1-a3 are on, thus channel 1. Then the second usb light went out. When I unplug the usb cable and plug it back in the device fails and the Hardware manager reports no driver installed, if I again do update driver the hardware manager reports the best driver already installed. Some times in the device manager the card shows as ‘unknown device’. I used some driver manager software to remove all the drivers and started from scratch, I as well tried different usb ports. This seems to be common on all 3 of my laptops, 1 old and 2 new, yet on my 2 desktop computers there was no issues.
C
