K8061 problems
hi,
yesterday i made the K8061 kit, and it seemd like it worked, i tested the board with windows 7 (the example for exel)
and today i tryed it again wit the demo, this said that my cpu failed, but when i try it again with the exel, it works normal.
grts jens
If you run now again the demo, is the message “CPU FAIL” still there?
Does it help if you disconnect and reconnect the USB cable and the power supply and then run again the demo?
wel i tried it again today, and same thing, re-connected it to power and usb, but still the same.
the all the leds that should be lighted are on, i dont realy understand what i’m doing wrong
[quote]the all the leds that should be lighted are on [/quote]So the RUN LED LD12 and the RX/TX LED LD11 are lit. This indicates that the CPU IC6 is running and there is data communication between the two microcontrollers IC3 and IC6.
Are you using the driver and the DLL of the latest software package?
If not, then please download this new software package for the K8061:
velleman.eu/downloads/files/ … k_2011.zip
The package includes new driver and new DLL.
There are example projects written in many programming languages included.
You have to remove the previous driver and install the new driver (v1.0.0.6) from this download package. Please read the Getting_Started.pdf and the README.TXT.
