hi velleman;
i have problems with the k8061 as follows:-
in my system the cards are to work with a no. of 12V & 24V plungers.
sometimes(3 out of 10) unexpected signals(usually from the digital
outputs) evolve when the plungers are working. if i cut the power
to the plungers the system is working fine. i read from the posts
records that alexart might have the same problem(he posted it
in sep-08-13). what can i do to solve this?
what is the difference between k8061 & vm140?
thank you for your attention.
regards. from kit
i’ll tell you the result in a couple of weeks; but the cables provided
for the i/o terminals are not shielded. should i shield the 20cm cables?
2)do you mean that if i order the k8061 i have to solder all the parts
onto the pcb and test it before it can be used?
[quote]1) i’ll tell you the result in a couple of weeks; but the cables provided
for the i/o terminals are not shielded. should i shield the 20cm cables? [/quote]Difficult to say if there is any help or not…
You may first try adding 100nF capacitors between the used input/output terminals and GND.
[quote]2)do you mean that if i order the k8061 i have to solder all the parts
onto the pcb and test it before it can be used[/quote]Yes.
[quote]1) could it be better if the 100nf caps are pre-installed onto the k8061? many people might have the
same problem;[/quote]Yes, this could have been a reasonable option.
[quote]2) any other way/s suggestion/s to further increase the success rate(95% is never good enough)?[/quote]The next step may be to put the whole K8061 board in a metal box.
Connect the box to the GND of the board.
Connect all the cable shields to the metal box.
You may also use feedthrough capacitors and put all the wires to go through these capacitors.
