what does the setup.exe programm do, what the Dll call opendevice not do?
I only get back the “card not found” message.
The exe programm in the software folder also only get the “card not found” message but k8061 from the list from the setup.exe runs the programm so, that the card will be found. What is the difference? What does the setup.exe programm do, what the Dll call opendevice not do?
Where did you get the setup.exe program?
There is no such program for the K8061.
You can download and try this new software package for the K8061:
velleman.eu/downloads/files/ … k_2011.zip
The package includes new driver and new DLL.
There are example projects written in many programming languages included.
There is also manual K8061_DLL_manual.pdf included describing all the DLL functions
You have to remove the previous driver and install the new driver (v1.0.0.6) from this download package.
Please read the Getting_Started.pdf and the README.TXT.
Thank you for your answer and the link to the DLL, which works correctly. Why could’t I find this DLL on your hompage (k8061 download) ?
The setup programm is on the CD, which belongs to several kits. It opened a window based on a List, which contains the path to the programm. If I startet it over this Setup.exe List then it runs correct, but if I starts it out of the associated folder it doesn’t work.
However, your new DLL runs well. Bye
