K8061 low reading
Hi hope someone can help.
When I connect exacly the same physical hardware to the analogue inputs in turn one is reading about 200 or so lower than the rest ie 7 return 445 (ish) and ad input 2 returns 223 (ish).
Is this a bust board/chip ? I have checked all my connections and all are physically sound.
Any help appreciated.
It seems the jumper AD2 is not making connection or resistor R45 has no connection.
Here you can download the K8061 circuit diagram:
box.net/shared/2o4jxf9yuu
Excellent … thanks very much, you were right jumper ad2 wasn’t quite seated.
Thanks for your help
