K8061 + k8055
K8061 works 95% perfect but still data loss occurs suggestoions advice ?
The effect caused by the OS ?
How 100% reliabilty of K8061 ?
K8061 should work perfect.
Greetings
Just wanted to know if the distubance from the LAN could … stopped
Also important for all LAN device
data has to … 100% safe
advice nice
Are there plans to develop a mre sophisticated board ?
Need one with more channels for detecion.
sincerly Greetings nice day
[quote]Are there plans to develop a mre sophisticated board ?[/quote]At the moment, there are no plans for such version of board in the K8055/K8061 series.
You do know that you can connect 8 cards to one PC?
power consumption through USB port : approx. 60mA
[color=#BF0000]up to 8 cards can be connected to PC[/color]
power supply through adaptor : 12Vdc / 300 mA (PS1205)
PWM Frequency: 15,6 KHz
standard execution time: 48mS (use Microchip and K8061D.DLL drivers)
enhanced execution time: 21mS (use K8061_C.DLL)
dimensions: 7.7 x 5.6 x 0.8"
minimum system:
    pentium class CPU with free USB port (1.1 or higher)
    windows 98SE or higher (Win NT excluded) *
    CD ROM player and Mouse
(*): Windows XP recommended!
(*): Are registered trademarks of MICROSOFT CORP.
Thank you for the quick reply
dont want to change the board K8061 suggest a new board to develop
idea:
the board should stop disturbance from the lan caused e.g. by hack or a manufactur-- of the OS system who can send unknown (harmful) content
the board should only allow well known package_ to pass the board
well known package is for e.g. your adress which may pass the board
this is also interesting for home applications which your company also develops
What happens if data detection because of disturbance- is not 100% correct the people will demand reliability from the company
or dont use the product
there is a need for such a product everybody needs such a board
the board should detect the electrical signals so that the whole data can be read
also found disturbance even if Lan routing is of
someone renamed or deleted even influenced jpg data when routing started like attached 23029 file etc.(normally K8061 should give 100% correct detection see like 193631 file)
the conclusion is that such a board is needed
there is a big sale potential for such a board
Greetings nice day
Can someone develop such a board Greetings nice day Greetings
Thank you
still have the problem of data lost. We let the card “work” 24h aday the software some time dont detects for 15minute data then for hours everything detected we are not quite sure if this effect come from lan or caused by the operating system or EMC . There is also still the effect that we detect insead of every 10s at 12s so there is additional 1s . So there may happen two effect data lost and a time delay.
Seriously is the firs effect that for a long period no data is detected. What can we do? We want to sell the software but if then data is missing well get problems that no one wants to use our program. Believe that the card was construced as well as done advice nice
thank you MfG sincerly nice day greetings
[quote]still have the problem of data lost. We let the card “work” 24h aday the software some time dont detects for 15minute data then for hours everything detected we are not quite sure if this effect come from lan or caused by the operating system or EMC[/quote]To try to “isolate” the problem, can you run the software in a laptop PC who is not connected to LAN or any other external circuit or network?
Does the loss of data occur in this case too?
Are there long wires connected to the input or output terminals of the K8061? If yes, there may be EMC problems.
with out lan there was no data lost major failure for one day connected the the lan and for hours e software runs stable the problem tat we had that for 20 minutes no data was detected didnt occur we only have the question that while 2 hours we detected that instead of 711 points only 704 were detected. Also the oprating system has only minor faults. Hope that this situation continous.
MfG thank you nice day greetings
Hello could you give advice which routing manufactur__ exist
we believe that the disurbance came from Lan now we dont have data lost
like your products
sincerly thank you nice day MfG greetings
[quote]we believe that the disurbance came from Lan now we dont have data lost[/quote]Strange problem, indeed.
Hello since a few days we have failure:
data not saved
break point was set so that program stopped (we didnt did that)
acoustical signal even when we didnt used the machine
major mal functions of operating system
we believe that the lan caus the failure
even if we havent lan we have minor failure charms is visible and such things
we want to sell the program that we developed and we even had problems to upload a file
suddenly wrong word were uploaded
how can people work with such a system ?
or do they use the system to spionage people
and the industry ?
we hope that someone invents a stable system.
ecma should do that
which hub do you use if we kindly may ?
we need a box that stops the failure.
when do we have a reliable system ?
if someone wants to debelop the system and the box please contact 64Software@gmail.com
due to the fact that we only have only 200-300euro avaiable each month we need sponsors who support our ideas
back to the topics who is the resonsible eu ecma chief ?
do you have contact ?
sincerly thank you nice day greetings MfG
