Bonjour,
Suite à vos éclaircissements, j’ai fait l’acquisition de 5 cartes USB K8061.
Je viens d’en monter 3 : les premiers essais donnent toute satisfaction et je suis très content de ce choix.
Afin de ne pas monopoliser toutes les entrées de la machine, j’avais acheté aussi votre HUB USB11 à 4 entrées .
Malheureusement, alors qu’il fonctionne bien avec des accessoires standards (lecteur de disquettes USB p.ex.), il me réclame la fourniture du driver “mcpush.sys” de Microship Technology Installation Disc. quand je souhaite y brancher l’une des cartes K8061…
Ce CD n’est pas fourni avec votre pack… Comment puis-je procéder ?
cordialement,
jjt
The file “mchpusb.sys”? is on the KITSOFT CD in the folder:
D:\K8061 extended USB interface\USB_driver
Thank you for your answer but : what is “KITSOFT” CD ?
I have only “VELSOFT2”, the CD of K8061 Kit !.. (no CD with mcpush.sys and no CD with the Hub USB !..)
jjt
The file I mentioned is one of the K8061 driver files. It is also on the VELSOFT2 CD.
But your system is asking for different file “mcpush.sys” - really?
[quote=“VEL255”]The file I mentioned is one of the K8061 driver files. It is also on the VELSOFT2 CD.
But your system is asking for different file “mcpush.sys” - really?[/quote]
Sorry, but I confirm that I don’t see mcpush.sys on my “VELSOFT2” CD !..
My system ask me “mcpush.sys” of Microship Technology Installation Disc
Thank you for your help !
jjt
You must point to the driver folder on the VELSOFT CD:
D:\VM140(K8061)_driver
–> Here are the driver files located.
[quote=“VEL456”]Hello,
–> Here are the driver files located.[/quote]
Her is the content of every one of my five VELSOFT CD: (the five CD are same…) :
- Acrobat PDF reader
- CD printing label
- PC-lab2000SE
- PC-lab2000SE manuals
- PC-Lab2000SE tools
- PCSU1000_driver
- Product Manuals and info
- Product Promotion
- WIN98SE HID driver
- Autorun.inf
- Readme1E.txt
- Setup.exe
No trace of " VM140(K8061)_driver" !!..
I have mailed the driver to your address…
Sorry but, in this time, no driver in my Incredimail !.. ??.. Really mailed at good adress ?
Thank you
jjt
Mailed to the address you filled out: jjtriadou@free.fr
Did not receive error message, so should have gone trough.
You can also look up the file with e.g. Google and download it from the net.
[quote=“VEL417”]Mailed to the address you filled out: jjtriadou@free.fr
You can also look up the file with e.g. Google and download it from the net.[/quote]
This adress is correct but I’ve not message !..
Please is it possible for you to mail an other time the driver with a “Request Read Recept” to be sure of the transmission ?
Thank you
Final attempt :-):
You can download the file here:
http://downloads.velleman.be/d06c90aab87688d44ef47cbe95f9013e/mchpusb.sys
If this does not work, your only option is to look up the file and download it from the net.
[quote=“VEL417”]Final attempt :-):
If this does not work, your only option is to look up the file and download it from the net.[/quote]
Thank you for this link. I’have immediately downloaded and the modules worked properly after our very long correspondence…
(The mistake was an incorrect name of the driver : “mchpush” instead of “mcpush”…).
jjt
