I just finished my K8061 but as I put 12V on the board, the run led starts flashing.
The input leds are working as I can turn the leds off with the inputs.
When I insert the board to my USB port, the power led comes on but thats it no USB led or connection.
I saw in prior posts that I should check pins 1,11 and 32 of IC6, they are all on 5V as they should.
pin 14 has 2,39V
Also I checked X2 which gave me 2,39V and 0,76V(last has a wave on top), I saw that the last should be 1,97V (at least between 1-4V)?
Can anyone give me an idea what to check?
. After changing both capacitors all was well. Great toy!
