I’m using the K8061 with Python using ctypes and access it from different threads.
Somtimes I can see Error messages on the console output which are comming most likely from the dll directly.
Is there a list of errors with explanation?
Sometimes my apllication crashes (Python.exe has discovered a problem and needs to close) Then the run mode led flashes.
Somtimes the device is still in the device manager list, but the demo8061 cannot find it anymore.
Sometimes it disappears even from the device manager list.
Recovery is possible by plugging the USB out and in again.
Reading analog inputs I often get wrong values if my application is busy.
I already exchanged USB cables and hub and used different K8061 boards and PCs.
Please help.
dan2010
