Hi
Where can I find a driver for K8061 / windows 7 / 64 bits?
Thanks in advance.
You can use the latest driver K8061 driver update v4.0.0.0 available here.
To install the driver on 64 bit Windows, you have to disable the driver signature enforcement.
In 64 bit version of Windows 7:
Press F8 when Windows is booting up until you get the Advanced Boot Options menu, then select “Disable Driver Signature Enforcement”.
Here you’ll find the instructions how to disable driver signature enforcement in Windows 10
I prefer to use option two.
