I need some connectors for my board because the wires are to short. Can i use these: http://www.velleman.be/nl/en/product/view/?id=353764 ?
These connectors are not suited.
If you need longer wires, you could remove the pins from the supplied connectors by means of a small screwdriver and solder longer wires to them.
