K8061 card
hello,
I would like to buy a k8061 card.
But I need 3 specifications before purchase.
  1. Can I do an external command with digital inputs to make a A/D conversion in the 10 bits analog inputs and what is the minimum time between 2 instructions.
  2. What is the minimum time between 2 A/D conversion.
  3. whtat is the USB transfer rate in this card
Thanck you for your help.
The answer to your first question is “Yes”. You can activate the A/D conversion by the digital inputs in your application software.
The answer to your other questions is: “general response time: 4ms per command”.
See:
velleman.be/ot/en/product/view/?id=364910
