is it possible to connected the extended usb board (K8061) with IR 15 channel (K8050)
It seems not to be written into the compatible list.
greetings and thank you,
[quote]is it possible to connected the extended usb board (K8061) with IR 15 channel (K8050)[/quote]Yes, this is possible. The K8061 has similar digital inputs as the K8055 on the compatibility list.
