K8060
I have recently assembled the K8060, and there is a problem with it. When i connect power, R2 is getting fried after a few seconds. I have changed it to a 1 watt, but it still doesn´t work. Any suggestion on what may be wrong?
Please check the numerous posts on this item.
Most likely, it is an assembly problem.
