OK - for the benefit of my fellow builders, particularly those in the UK sourcing additional components (transformer and heatsink) through Maplin…
I have finally got the kit working and I’m really pleased with it. The bits that I’ve had to work out for myself are:
The Maplin heatsink is too short to mount the power transistors T7 and T8 as indicated by the manual. To get aound this I mounted the transistor connectors to the REAR of the board with the long side soldered into the PCB and the short side facing inwards, so if you look at it from the side it looks like:
[color=#FFFFFF]-----[/color][color=#000000]-------------------[/color][color=#FFFFFF]-----[/color]
[color=#FFFFFF]------[/color][color=#000000]|[/color][color=#FFFFFF]------------[/color][color=#000000]|[/color][color=#FFFFFF]------[/color]
Then mount the power transistors to the connectors so that the finished assembly looks like this:
[color=#FFFFFF]-[/color][color=#000000]===|[/color][color=#FFFFFF]-------------[/color][color=#000000]|===[/color][color=#FFFFFF]-[/color]
Then work out the position for your drill holes on the heatsink. To make it that little bit better I also mounted the LED underneath the board and matched it with a hole in the heatsink to give a visual indication of power on/off from the exterior.
To reiterate the points made above in this thread - be really careful to spot the difference in the two power transistors T7 and T8 (TIP147 and TIP142) before mounting, and double-check before powering up. Anything wrong in this area will again blow the 1a fuse and probably damage other transistors, although there will be more on this when I rebuild the non-burnt-out board to see if the fuse protected it. DON’T be tempted to use a higher-rated fuse - I did and set fire to four resistors!
Transformer connections for the Maplin unit are as marked on the board, working anti-clockwise - Y - Yellow, R - Red, B - Blue, G - Green. This has the effect of shorting Red and Green as a centre-tap, giving c70v AC between Yellow and Blue, which you can test off the board to be safe. If you use the 1a slow-blow fuse specified when testing, connecting Red and Green together and measuring across Blue and Yellow will NOT blow the fuse, but an incorrect configuration will - a good way to test before committing power to the board.
OK - you’ve tested and connected the transformer, you’ve double-checked the power transistors and you’ve run over everything obvious with a multimeter to check for potential shorts. Obvious ones are between the pins of the power transistors, from the metal body of the power transistors to the heatsink, signal in/ground, speaker out/ground and +40v/-40v on the end of the rectifier diodes. Ensure VR1 (bias adjustment) is turned fully anti-clockwise, and that nothing is connected to either input or speaker terminals.
Connect AC power and check the LED - it should light and stay lit. There should be no discernable hum coming from the transformer. If the LED lights and then immediately goes out the fuse has blown - re-read the above notes on the transformer and the power transistors first because that was the cause of the problem in my case.
Next check the voltage across R19. It should be zero or close to zero. Turn VR1 up and the reading from your tester should start to rise, slowly at first and then much more quickly. If you’re lucky at around the 9 o’clock position it should rapidly rise above 10mV - wind it back to 10mV and let it rest for a few minutes before giving yourself a pat on the back for a job well done!
If not, as it did with me first time around, the maximum voltage I could reach with VR1 turned all the way to the right was 3.3mV. This again seems to be quite common.
I started by checking for continuity between all the components using the circuit schematic at the back of the manual. Eventually I traced the fault to a dry joint on the collector of T8 - found by checking resistance between the +40v at the top of the rectifier diode and the middle pin of T8. Resoldered the joint, re-assembled the board back to the heatsink, tested again at R19 and easily found 10mV. Hey presto - the amplifier now works exactly as I wished for.
So, in summary:
Reposition the power transistor connectors as described to make the whole thing fit on the Maplin heatsink;
Make sure you mount the correct power transistor to the right connector T7 is a TIP147, T8 is a TIP142;
Wire up the transformer as described - the colour letters on the board are correct;
If the fuse blows the transformer and/or power transistors are the most likely candidates - look there first;
If you cannot get 10mV over R19 refer to the circuit diagram in the manual and start working component to component checking for continuity.
Stay with it - you will get there and when you do, it’ll all be worth it!
All the best,
Tony
