K8060 power transformer
I have just now build two K8060 amps and wondering if my power transformer is too big? I have two 2x24V 220VA, is that too big?
Or can I use those?
Should be fine. Output power will be 15% reduced.
OK, tested with light bulb and it went off and now lights up light.
:oops: my bad…one kondensator wrong installed…
now working!!
Allways take a friend to check your installations!!! :lol:
When did you buy your K8060 ? There are lots of kits that don’t work. The stock answer is “the semiconductors must be faulty!” or You are a C**p builder". This forum tells you to get new semicondonductors" yea from where ?
I bought it last week, from finland. All components thats used can be found from elektrical stores. I found every component from http://www.elfa.se/
Theres few pictures from my amp
http://komarus.spaces.live.com/photos/cns
All Velleman dealer can order every spare part, except some programmed devices.
