K8060 Maximum AC Voltage Input
What is the maximum AC voltage tolerance of the kit?
I understand 2x 25v - 2x 30v transformers are recommended, but I have a transformer with 2x 35v and another with 2x 38v! I would like to use the K8060 kits with these transformers.
I assume after regulation the DC voltages would be 49v and 53v respectively. If this is too high, perhaps a regulator could be implimented or changed in the system?
Many thanks in advance.
2 x 30V is the max. allowed transformer rating.
Most simple and reliable solution is to get the right transformer.
