K8060 + K8084 for bass guitar amplifier
Hello, I was just wondering if a K8084 would be good to drive the K8060 in a bass amp application, and if so, how should I go about powering it? I would like to mount the two kits into one box as a traditional guitar/bass amp head. The K8060 will have a 2x 30VAC transformer, but I understand the K8084 needs 2x 12VAC - will it need a separate transformer, or is there any way I can somehow connect to the 8060’s supply and drop the voltage down to 12?
Many thanks in advance.
For best results, we’d recommend two transformers.
Thanks for your reply! I shall use two transformers.
Could you confirm that the K8084 would work okay in a bass amp application? I am aware there is a mono-preamp kit available which will allow me to increase the gain, but I would like the ability to adjust bass and treble also, hence the 8084.
Thanks again :slight_smile:
Should work fine.
Treble control won’t do much, we assume :slight_smile:
Great, thanks for your help! I will post my findings :slight_smile:
