I did the bias adjustment on my finished amp without any problem. LED came on and adjustment was fine.
I then connected an 8ohm speaker (I also changed the LED for one to go on my front panel), connected a pot and input jack and Earthed the R transformer connector to the chassis. As soon as I powered it on the speaker gave a humming noise (not too loud) and the LED came on but then the 1amp slo blo fuse blew in about 1 second.
I also have your dual 1amp psu kits running off of the same fuse but it’s only supplying a small opamp mixer. Would that likely be drawing too much current? If so what fuse should I use. 2amps seems too much.
Because the bias adjustment went OK does that eliminate the PCB and components?
Also can I try it with the output open circuit safely(ie no speaker)?
By the way I have it sitting in a chassis next to another one which are touching - although the power transistor metal is insulated from the other.
Any suggestions or likely causes are very much appreciated.
