Well I’m back to the K8060 which I shelved for a whille in frustration. I’ve replaced all the semiconductors and still have a problem with the bias being too low. . The amp generally works but its not loud enough and distorts.
Can anyone give me a few pointers as the the voltages in various parts bias circuit when the bias is set properly (i.e. in the bias set up part with no input) ? This might give me a clue as to which component is dead/not working correctly. i’d like to compare values in the resistor chains etc. i assume the Vbe of the TIPs must be a little above 0.7 volts at least.
Also the bias pot is a 1K7. Would this cause a problem since its specified as 500ohm on the circuit diagram?
The bias voltage across R19 is maximum 1.5mV. I changed out the IN4148s as well.
Please help!!!
Jules
