K8060 and 12V supply
Hi.I assembly one of this Kits and make a test with 2x torroidal transformers 12V 50VA before power diodes.Now the amp work perfectly for my requirements.My question is:Can i use the amp normally with this half power supply?
Thx
No, this is a dual supply amp. It will not work with a single supply.
Yes,i know it,and i just use 2 torroidal transformers,each for the double supply.The amp working good for now,but im worry about the components.Can i damage the amp with lower supply?
No, you cannot damage it with a 2x12V supply.
Ok.Great! Thanks for the answers.
