I’ve bought a k8059 kit from a local distributor, I think the plastic bos was opened because it seems that is missing some screws or bolts or something from the plastic box, and after I’ve mounted the components on the board, the buttons from the plastic case was missing. The kit works perfectly, but I cannot use it without the plastic case…
First and with a bit of luck the fastest way to the solution: go to your local distributor and try to solve it together. Your distributor can arrange that for you.
If that does’n work: Velleman will be glad to help you but this can take a little more time.
Your distributor can order a new enclosure for you.
Order code: BKEYCHAIN
