K8056 problem with serial port, VB 2008
I 've just finished my K8056 Velleman kit. I Try to write a program in VB 2008 but I don’t really know how to use VB.
here my program, I just want to set the relay n°1 with a button
Imports System
Imports System.IO.Ports
Public Class Form1
    Dim Port As SerialPort = New SerialPort("COM1", 2400, Parity.None, 8, StopBits.One)
    Private Sub Form1_Load(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MyBase.Load
    End Sub
    Private Sub Essai_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Essai.Click
        Port.Open()
        Port.Write(Chr(13) & "1" & "S" & "1" & "88")
        Port.Close()
    End Sub
End Class
How can I calculate the Checksum, is it really necessary?
what is the code to configurate the serial port, is it correct?
thanks for your answer
fred
Sorry, I have no VB2008 experience.
Regarding the checksum calculation, please check the VB6 demo source.
ok but do you have any example with VB6?? It should be almost the same program…
regards
See above: The source code of the demo program is available for download. It contains all possible commands for this item.
You serial port settings are correct :slight_smile:
velleman.be/downloads/files/ … b_demo.zip
Try reusing the calculations made in the VB6 code and see if it works
ok thanks for your answer but i think the problem is in the parameter that i try to send to the card: CHR$13 (is it 0x13 in hexa?), adress 1 (in hex?), S (in ASCII code?), adress 1 (in ASCII code?):
00010011 : CHR$13 (ASCII)? or 0x13 in hex
00000001 : adresse of the card --> 1
01010011 : instruction ‘S’ in ASCII
00011001 : nb of the relais --> 1 or 0x31 in hex
10000000 : addition
01111111 : 2-complement
00000001+: add one
10000000 : checksum=128??? is CORRECT??
Nothing happen on the card but with the demo program, it’s working…
fred
13 = 0x0D
 1 = 0x01
83 = 0x53
49 = 0x31
i’m not entirely sure, but try 18 (0x12) as the checksum
in hex: - (FF - (0D+01+53+31)) = -6D = 12
ok thanks but what about the +1??
I understand (FF - (0D+01+53+31)), I suppose it’s the 2-complement but why do you put a “-” before all the equation??? (sorry i’m a beginner)
fred
PS: I suppose that the Led D10 on board is red only in case of a good communication between the card and the pc??
Just to say that I found the error: Here my program in VB2008 just to communicate with the K8056 board and set the relay one. I can send you the code when i will finish it if you want.
[code]
Imports System
Public Class Form1
Dim Port As IO.Ports.SerialPort = My.Computer.Ports.OpenSerialPort(“COM1”, 2400, IO.Ports.Parity.None, 8, IO.Ports.StopBits.One)
    Port.Close()
End Sub
    Dim messagestring As String
    messagestring = Chr(13) & Chr(1) & "S" & Chr(49) & Chr(110) 'number in decimal
    messagestring = messagestring & messagestring
    Port.Open()
    Port.Write(messagestring)
    Port.Close()
End Sub
End Class[/code]
Thanks for your help…
see u
PS: for the checksum in hexa: [FF-(0D+01+53+31)]+1 = 6E or 110 in decimal
Hi all
I found out that the formula of the demo program may get a wrong checksum of 256 while using the command “Send a Byte” with the value 176.
That’s why I came to the following solution to get the checksum for the K8056 in VB6:
Public Function funcChecksum(bytAddress As Byte, strCommand As String, bytValue As Byte) As String
Dim X2 As Integer
X2 = 13 + bytAddress + Asc(strCommand) + bytValue
X2 = Not (X2)
X2 = X2 + 1
X2 = X2 And 255
funcChecksum = Chr$(X2)
End Function
hi all,
Here a routine function in VB2008 that works with the good formula for the checksum… address, command and relay_nb are integer.
[code] Public Function instruction_card8056(ByVal address As Integer, ByVal command As Integer, ByVal relay_nb As Integer) As Integer
    checksum = ((255 - (13 + address + command + relay_nb) + 1)) 'complément à 2 des 4 bytes
    messagestring = Chr(13) & Chr(address) & Chr(command) & Chr(relay_nb) & Chr(checksum)
    messagestring = messagestring & messagestring       'double envois de la commande
    Port.Open()
    Port.Close()
    Sleep(200)      'pause de 200ms entre 2 commande
    Exit Function
End Function
[/code]
Some define in the beginning of the main:
    Dim relay8 As Integer = 56 ' number "8" in ASCII
    Dim relay_on As Integer = 83 ' "S" character for SET
Here is a vb sub for sending the command “B” (send a byte)
using Val7654’s formula
[code]Private Sub K8056_SendByte(Relays As Byte)
'oparates 8 relays of k8056 with address address
Dim checksum As Integer
checksum = 13 + address + Asc(“B”) + Relays
checksum = Not (checksum)
checksum = checksum + 1
checksum = checksum And 255
factor = RTrim(LTrim(Chr$(Relays)))
messagestring = Chr$(13) & Chr$(address) & “B” & factor & Chr$(checksum)
MSComm.Output = messagestring
End Sub[/code]
