K8056 commands
Hi I need some help with the serial commands the K8056. purchased it to use with a control system that have serial ports. ATEN VK2100. however in the user manual did not find the needed commands. I just need to commands to turn on and off each relay on the board from 1 to 8. ASCII commands
You can down load the software and demo package from here
http://www.vellemanusa.com/support/downloads/?code=K8056
The assembly manual in this link will give you the format of the commands starting on page 10.
http://www.vellemanusa.com/downloads/0/illustrated/illustrated_assembly_manual_k8056.pdf
