K8055N on Windows CE
I would like to control the K8055N board from a Windows CE 6.0 device that has USB host ports. I’ve seen that the communication is done through the K8055D.dll that is a native code dll that will not work in WinCE on an ARM cpu (i guess…).
Is there a way to do that? Can you maybe recompile the dll with the WinCE SDK on ARM CPU so that you extend the compatibility of your device? If there is a way to let it work on WinCE I’ll buy the first 20 boards.
I hope to hear something ASAP, I have to make 20 devices and I’m evaluating what to use.
Thank you in advance!
It seems to be not possible to control the K8055N board from a Windows CE.
Please see:
viewtopic.php?f=3&t=5142
viewtopic.php?t=5155&f=12
