K8055D.dll "Version 2.0.0"
I am a teacher for sport and computer science in germany . In the 11th grade we are programming an interface for the VM110 interface board with Java.
I have a problem. I need the Dynamic Link Library “K8055D.dll” but only “Version 2.0.0” (not a higher version or a lower version) to get a connection to the board.
It would be of great help to me if i can get these old “Version 2.0.0”.
Thanks a lot,
nguenther
Here is the link to download this early release of the DLL:
vel255.diinoweb.com/files/K8055D_DLL_v2.0.0.0.zip
Thank you VEL255 for your immediate reply.
I downloaded the file and integrated to System32. By all the rules the programm had to work but it doesn’t. Probably there is a different between “Version 2.0.0” and “Version 2.0.0.0” of K8055D.dll.
Is this possible?
The program works with a certain .jar library(programmer Thomas Wenzlaff wenzlaff.de and TWUsb.jar) I integrated to system32 and correctly imported to eclipse environment. The program have to work with this library, that contains Java methods to get access to the board. Additional the library needs “Version 2.0.0”.
It seems that I get access to the board, but as soon as I try to set AllDigital with the corresponding Java-method nothing happens.
Additional I have a Delphi-testprogram. Here I can see that the board works. I can control outputs and inputs.
It would be of great help to me if I can get some more information what I shall do, and maybe I can get this old “Version 2.0.0” of K8055D.dll.
Thanks a lot,
nguenther
I’m sorry but the version 2.0.0.0 is the oldest version of the DLL I have from the company RE-Applications.
The older version I have is the original on the Velleman CD (without version number) from the year 2003.
Do you know if this version 2.0.0 is also written by RE-Applications?
If is, you may contact www.RE-Applications.be and ask if they have a copy of this version.
