K8055D_C.dll Beta problem
I tried using version 3.0.0.0 (Beta) version of the K8055D_C.DLL and I received the following errror:
                             "Entry Point Not Found"
“The procedure entry point_OpenDevice@4 could not be located in the dynamic link library D8055D_C.dll”
I replaced version 3.0.0.0 with the original version 2.0.0.1 and the program works fine. Is there something else I need to edit or alter something in the source code in order to get version 3.0.0.0 to work?
Sorry there is no v3.0.0.0 of the K8055D_C.DLL only K8055D.DLL.
The K8055D.DLL is only for Visual Basic and Delphi applications.
You may use this DLL if you use dynamic DLL Loading in your application.
