K8055d and 64 bit systems
Could any please tell me why my k8055 board is not working on a new laptop. When i try to install the demo program a message tells me that this version will not work on my current system. I have previously run this card successfully on a 32 bit Windows XP system. I am now running a 64 bit Windows home premium system.
I did see in the forum that moving the k8055d.dll to the windows\WinWOW64 directory resolved another problem with a 64 bit system, but this although allowing a program written in VB6 to actually run without error does not seem to accept input from the USB port.
I am using the k8055 board to read from an analog input and convert to digital signals that the computer can read. The board is fine I think it is the 64 bit system that may require another driver.
Can any one please help?
Here’s the link to download the latest K8055 software package with examples and with new K8055D.DLL: velleman.eu/downloads/files/ … rsion4.zip
After extracting the package you can first run the K8055_Demo.exe in the \Demo subfolder.
In the examples subfolder there are example projects written in many programming languages.
Before running the example projects, please copy the file K8055D.DLL from the folder \DLL_v4.0.0.0 to \Windows\SysWOW64 folder.
(In 32-bit environment copy the file to the \Windows\System32 folder.)
Thanks for the extremely speedy reply. My program now works fine. Information was easy to follow and worked straight away.
Once again thank you.
