Hi all,
Is it possible to control the K8055 card with a web based interface (apache or IIS) ?
and if yes where could i found some examples ?
Thanks and Bst Rgds,
Hi all,
Yes, it’s possible.
But only tested with apache, not ISS
ok thank you, but under windows with appach is it working ? and how ?
because i have tested it with Visual Basic, but i want to use it in a full web application and i am not
a god off linux
Where could i found some examples
Bst Rgds
Hi, his there somewhere somebody have some example to use a K8055 under Windows web server
with CGI or PHP Script ?
Thanks for your help
You should be able to develop your project in ASP.NET as it will use VB.NET coding which will run on IIS and will work with the K8055 DLL.
This freeware is witch webinterface and serveur k8055
[color=#0000FF]http://k8055.info/?id=1[/color]
Nicolas
