hi.
is it possible to connect an IR diode to the K8055 board.
I would like to use my computer to send out IR signals to control my receiver/amplifier.
first of all I need to know what signal the remote control of my receiver sends out, therefore I have a IR “receiving diode” (white transparent diode). I would like to connect it to an input on the board, but is the board fast enough to “record” the signal received??
secondly I want the board to send out IR signals through an IR diode (dark blue / black diode). on what output can I connect it, or again is the board fast enough to send out the High frequent signals?
If it’s not possible to do with this board, is there maybe a add-on for this board or maybe another product I can connect to my PC (only USB available) or is it easy to solder myself.
I have used the K8055 now for updating my home made computer controlled relais.
http://vanprooijen.net/projects/pincontroller.php
thanks all!!!
