After programming via VB in Windows XP, can the VT110 be disconnected and powered externally( as on p8)? Can it also be controlled via a USB memory stick?
[quote]After programming via VB in Windows XP, can the VT110 be disconnected and powered externally( as on p8)? [/quote]This is not possible. The PC is needed to control the operation of the K7055/VM110.
[quote]Can it also be controlled via a USB memory stick?[/quote]Also this is not possible.
