I have a problem with a K8055 (green board with P8055-1 number on it) board. The board is a part of a bigger projekt and is not recognized by the computer any more.
The programming is very old and the source code is gone. I need to replace the broken board without touching the programming.
My questions are now:
Is the programming really 100% NOT ON THE BOARD and only on the computer, so that I can just replace the board (with the right jumper positions)?
[quote]2) Is the newer version (velleman.eu/products/view/?id=404880) 100% compatible with the older board (K8055)?[/quote]Yes, except the PWM frequency is 46.875kHz instead of 23.43kHz of the K8055.
[forum.vellemanprojects.eu/t/k8055n-pwm-frequency/8023/1)
It should be possible to use your original software.
thank you for the answer. Regarding to my first question:
Is the programming/software really only stored on the computer and not on the board?
I´m asking, because on some boards (Arduino and so on) you have to put the generated code onto the board (with a “upload code to board software”) and the code/programming/software is NOT stored only on the computer.
[quote]1) Is the programming/software really only stored on the computer and not on the board?[/quote]Yes, the application software is completely on the computer.
This should be the approriate thread to post my question: Existing software does not recognize a new K8055N board.
My customer works with an old version of the USB Bord experimental board in his plant. In order to rework the associated software we are using a contemporary K8055N. The existing software worked with the K8055N, only after replacing K8055D.dll with Version 5.0 from your website. The original K8055D.dll didn’t have a visible version number. It’s 338 kb in size and dates from July 1 2003, though. Now, we need to avoid different behaving software versions. A testing environment that makes any sense should behave the same way, the productive does, shouln’t it?
Now my questions are:
· The compatibilty statement seems not to apply to K8055N - or what could we have done wrong?
· Is there a documentation of version differences?
· Will the old board run with the new dll?
· If no: Is there a simple way to update the microcontroller firmware on the board
to the current version in order to make the old board run with Version 5.0 of K8055D.dll?
[quote]• Is there a documentation of version differences [/quote]The PWM frequency is different in the K8055N compared to the K8055.
K8055N: 46.875kHz
K8055: 23.43kHz viewtopic.php?f=3&t=10295
[quote]• Will the old board run with the new dll?[/quote] Yes, you can use the new DLL for the old K8055 too.
