Hello Velleman Forums
I have a K8055 USB experiment interface board. When I try to connect the board to three (3) different computers all Windows 10 64-bit all I get is.
“USB device not recognized”
I have looked in device manager and it is “Unknown USB Device (Device Descriptor Request Failed)” It has a ! next to it.
If you have any hints or tricks please help.
The K8055 should show up as a Human Interface Device (HID)
The drivers are built into the Windows O/S
You may need to up date the drivers from Microsoft.
Or you can try it on a Windows 7 or below machine to see if the assembly is correct.
LD8 should blink 3 times on start up.
On every computer that I have tried the LD8 light will blink 2 times then stay on.
I updated my laptop last night and it still did not work.
The only there computer that I have that is not 10 is running XP but I do not know if I could even get it running.
I have just got an Active USB hub and the same problem persists. When I plug it in the led ld11 turns on and ld8 blinks twice and then turns on and stays on. The computer does not recognized the USB device. Any other ideas?
