K8055 usb interface
This looks like a very interesting kit - but I haven’t bought it yet. Is it intended to ‘work’ with Windows Vista/32 bit/Visual Basic Express 2008/Visual C++ Express?
Yes it works with Windows Vista 32 bit and 64 bit versions. Also with Visual Basic Express 2008 and Visual C++ Express.
Here is a link to download the latest updates:
velleman.eu/distributor/supp … code=K8055
Download both of this files to get the example projects and the latest DLL:
Software DLL (Rev 3.0.2)
supports Windows Vista, VC++ version and executable examples
Software DLL Rev 2
older DLL with examples and source code (source can also be used with DLL rev 3)
Here also links to download my demo projects for the K8055:
VB 2008 Express:
box.net/shared/euf9bd2rc4
VC++ 2008 Express:
box.net/shared/jhm672nk6z
If anyone could be interested in a interface for k8055 written in Euphoria version 3.1.1.
Here is a part of the experimental code that works well on WinXPpro.
[code][color=#00FF00][size=85][size=50]procedure pollDll_K8055()
sDdll ={}
sCDir ="C:\\Windows\\system32"
sCurrD =current_dir()
    --0. Detect the presence of K8055x.dll.
    --   read path "C:\\Windows\\system32"
setText(nfoSelCard, " Search for the Velleman K8055x.dll :")
– addItem(lstCards, " Files K8055x.dll search : ")
for j =1 to 2 do
if j =1 then
   oD =dir(sCDir)
   addItem(lstCards, "   ")
   addItem(lstCards, "  " &sCDir)
elsif j =2 then
      oD =dir(sCurrD)
      addItem(lstCards, "  " &sCurrD)
end if
if not atom(oD) then
   iLenD =length(oD)
   if iLenD then
      --find all the K8055x.dll's:
      for i =1 to iLenD do
          if match(".DLL", upper(oD[i][1]))
          and match("K8055", upper(oD[i][1]))
          then
               addItem(lstCards, "> " &oD[i][1] &"  " &sprint(oD[i][4]) &"." &sprint(oD[i][5]) &"." &sprint(oD[i][6]))
               iCnt +=1
          end if
      end for
      if not iCnt then
         addItem(lstCards, "  K8055x.DLL   NOT PRESENT !")
      end if
   elsif not iLenD then
         addItem(lstCards, "  EMPTY DIR !")
         return
   end if  --iLenD
end if  --atom()
end for
end procedure
procedure openDllK8055()
addItem(lstCards ,"  open_dll(\"K8055D_C.DLL\")")
    --1. Open the DLL file that contains the C function
    --   by calling open_dll() contained in euphoria\include\dll.e. :
    --   A 32-bit address will be returned, or 0.
    --   The value returned by open_dll() can be passed to
    --   define_c_proc(), define_c_func(), or define_c_var().
aAddressK8055dll =open_dll("K8055D_C.DLL")
if not aAddressK8055dll then
   addItem(lstCards, "Couldn't open K8055D.DLL !")
   addItem(lstCards, "  address =" &sprint(aAddressK8055dll))
elsif aAddressK8055dll >0 then
      addItem(lstCards, "  K8055D_C.dll = OPEN.")
end if
addItem(lstCards, repeat('=', 40))
end procedure
procedure findCardOnOpenDevice()
iCardNr =c_func(aOpenDevice, {2})
if iCardNr then
   addItem(lstCards, "  OpenDevice(iCardNr =" &sprint(iCardNr) &")")
elsif iCardNr = -1 then
   addItem(lstCards, "  aOpenDevice(iCardNr =NOPE) !")
end if
end procedure
procedure blinkOrFlashLed()
aSetDigitalChannel =define_c_func(aAddressK8055dll, "_SetDigitalChannel@4",
                     {C_POINTER}, C_INT)
if aSetDigitalChannel = -1 then
   addItem(lstCards, "  SetDigitalChannel could not be found !")
end if
iSetDigiCh =c_func(aSetDigitalChannel, {1})       --aHwnd, aPs
if iSetDigiCh = -1 then
   addItem(lstCards, "  aSetDigitalChannel  nope !")
end if
sleep(1)
aClearDigitalChannel =define_c_func(aAddressK8055dll, "_ClearDigitalChannel@4",
                     {C_POINTER}, C_INT)
if aOpenDevice = -1 then
   addItem(lstCards, "  ClearDigitalChannel could not be found !")
end if
iClearDigiCh =c_func(aClearDigitalChannel, {1})       --aHwnd, aPs
if iClearDigiCh = -1 then
end if
sleep(1)
end procedure
[/size][/size][/color][/code]
