I have an issue with the AD1 / AD2 values that the demo software is displaying. The values shown for both the A1 and A2 inputs are approximately 208, although I have no inputs connected. The test potentiometers only increase the values having been turned about two thirds of of their rotation clockwise. The AD1/AD2 values will not drop below 208.
I am a novice at soldering, and this project has been the first bit of soldering I have done in 8 years, I have therefore probably gone wrong somewhere… but where should I look?
Any hints on what would cause the discrepancies in the input values would be much appreciated.
Please check the IC1 solderings.
It seems that it is not getting “ground”.
Do you get some values from AD1 and AD2 if you remove the jumper caps from the pin headers SK2 and SK3?
