I put together 2 K8055 boards and tested them with the demo software (just 1 board connected at the same time) : The 1st one is working perfectly, the 2nd one cannot connect (“card 1 not found”). I swapped the PIC between the 2 board, then the 2nd one is working. I did several tests: both boards work perfectly with the 1st PIC but not with the 2nd one.
This makes me beleive the problem is coming from the PIC itself, however the LED8 is flashing 2 or 3 times at startup then turns off…
I have same problem, k8055 1st time ok but after some tests crashes. I disconnected after 10 minutes and works again. I bought it in america but live in Spain, some quick-fix solution?
