K8055 to control curtain blind motor
I want to control a Somfy curtain motor from a K8055. The motor runs on 24VDC, with the direction of the rotation determined by the polarity. So I basically need to be able to switch 24VDC on and off, and reverse the polarity. Which is the best circuit to do this? Should I use the K2633 relay board? Is it possible to use the K2634 Triac board or does that handle AC only? The motor draws 0.38A
Thanks,
Michael
K2633 is suited for the job.
Triacs only handle AC
Perfect, thanks for a quick reply and excellent service!
