Hi
I am thinking of buying the K8055
The outputs are 50v 100ma max - could i drive relays from this? they would be switching 230v ac 5amps
I have searched for relays but havn’t found any yet.
I have one other question if you don’t mind.
I wish to wire in the inputs to a “1 wire” temperature sensor network do you think this would work, I would use the pc to read the network (if i can find the or write software ?)
it’s a very long time since i did any electronics and nothing like this stuff, so am a bit unsure of myself.
any advice would be appreciated
[quote]The outputs are 50v 100ma max - could i drive relays from this?[/quote]Yes, you can. Please see this thread for an example: viewtopic.php?f=3&t=3406
[quote]they would be switching 230v ac 5amps
I have searched for relays but havn’t found any yet.[/quote]Here a relay you can use: velleman.eu/distributor/prod … /?id=17775
[quote]I have one other question if you don’t mind.
I wish to wire in the inputs to a “1 wire” temperature sensor network do you think this would work, I would use the pc to read the network (if i can find the or write software ?)[/quote] Sorry, it is not possible due to the timing requirements of the 1-wire temperature sensors. They need microsecond scale timing. The K8055 can change the output state once every 10ms.
Thanks very much thats helped a lot.
What would be the best interface to my PC? do I have to have a micro controller Board?
I dont really want to get into programming micro controllers - I am pretty proficient in C# and VB.net But i’m not sure how to go about it?
Thanks again
Mike
The Velleman K8067 Universal Temperature Sensor is designed to use together with the K8055/VM110.
velleman.eu/distributor/prod … ?id=354616
(Also exists assembled and tested: VM132)
If you like to use the 1-wire temperature sensor connected to the PC, you can use Google to find a lot of applications and hardware: This search: “1-wire temperature sensor” “PC” gave for instance this link:
“Serial Port Temperature Sensors - Hardware Interface”:
martybugs.net/electronics/tempse … rdware.cgi
See also:
“Reading and Writing 1-Wire® Devices Through Serial Interfaces”:
maxim-ic.com/app-notes/index.mvp/id/74
Thankyou
Its funny, I have been googling for days on the 1 wire network but never came up with those two!
Mike
