Hi Guys, been using the K8055 for a couple of days to find it no longer works after my computer crashed while using the card.
When i plug the device into my pc the Power Led LD11 blinks once, and if i plug the cable in slowly it blinks 3 times, my computer then picks up the device as unknown. Any help would be greate.
It seems the PC disconnects the card.
Maybe there is too high current consumption on the K8055. The reason to this may be a defective component on the K8055 card or soldering fault.
As a test you may remove the IC3 and then plug in the USB cable and check the power LED LD11 behaviour.
