Hello
Unfortunately I moved the SK5/6 without power off /disconnect the board and now the pc does not recognize the board. Before that, the system worked well.
Is it possible to solve the problem with some of your advice?
Thank’ s in advance
Hello
Thank’ s in advance
To check the board, please do following:
Good morning
Actually when reconnect the USB cable the LED LD1 become on and not happen nothing.
Thank you
Regards
Isn’t the ‘Power’ LED LD11 ?
Anyhow, this may indicate some defect on the board.
Hello
The LD11 it’s on ever on
Regards
So LD1 and LD11 are both on?
Please check the IC3 is properly in the socket.
Check also the crystal soldering is OK.
Do you have K8055 or K8055N board?
Yes are both on and the IC and crystal seem ok
It’s K8055
Regards
It seems that maybe IC3 is damaged.
Possible cause: electrostatic discharge…
