K8055 set debounce time for digital input 3?
Some precise details of my little project :
  • I program in VB .net with Visual Studio 2008
  • I must create 3 buttons for a quiz. when one of the button is pressed a sound is played (2 seconds), a light is turned on (2 seconds) and the 2 others buttons are blocked (2 seconds)
This kind of button oblige me to set the debounce time at 250ms for each.
It’s not a problem for digital inputs 1 and 2 because they have each a counter and I can set the correct debounce time so the program functions well for this digital inputs
The problem comes for the digital input 3 who does not have a counter so when I press this third button I’ve got plenty of signals…
I thought of several solutions, but I don’t know if it’s possible :
  • create a third counter for the digital input 3 (?)
  • to use two K8055 cards and use digital inputs 1 and 2 of the first and the digital input 1 af the second (?)
thanks a lot for any help :wink:
You may also use a software debounce:
When the button “press” is detected, start a timer (250ms) in your application.
When the timer time is elapsed, check the button status again. If still “pressed” accept it as a button press. Otherwise reject it.
Here are more debounce solutions:
maxim-ic.com/app-notes/index.mvp/id/287
eetimes.com/discussion/break … debouncers
