In the manual it calls out for a bunch of 1k resistors but I only have 10k instead. Is this correct? Thanks.
Can you supply more information (e.g. resistor references ?)
Did you measure the supplied resistors with an ohmmeter ?
10k resistors won’t work, the resistance is to high. Your resistors are marked with a brown, black and orange bands plus a tolerance band. You need brown, black red, which are easy to obtain from a electronics shop or on the internet from someone like Maplin. You could put ten 10k resistors all together in parallel to make a 1k resistor but that would be silly.
Actually I did check them with my meter and they were infact 10k. I got some 1k’s on Sun and finished the board. Thanks
