i read that i need a frequency converter to run a 240v fan from pwm out1 on my k8055, and that they are very expensive.
my electronics isn’t that great (not a novice) but there must be a cheeper way around it ,
can i build a cheep low low voltage pwm to frequency cct and then step it up to mains voltage with another cct ??
Maybe the K8064 can be used?
The K8064 is not suited for motor control !!!
gutted
doesn’t the K8064 change the frequency of the mains ?? or does it just change the voltage ??
if not could you tell me of a frequency converter that would work. the fans aren’t massive but 200w would be nice
has anyone any idea’s how i can use the anolog pwm to control the speed of a 240v fan
or maybe using the dac not pwm
