Hi all,
I’m having an issue with my k8055 board. The pwm1 terminal is giving a 5v signal, while the pwm2 terminal is giving the correct open collector signal. Any idea what might be causing this?
Cheers.
Hi all,
Cheers.
It seems the base driving voltage of transistor T1 is output from the PWM1 terminal.
Possible cause:
