I’m new to Velleman products and to electronics in general, I understand circuit diagrams but have never really put this knowledge to use properly. I decided to expand my knowlede and purchased the K8055. I have built the cuircuit and it operates correctly when the ‘Demo_K8055’ program is run but I am unable to find the software use to program this product. Can anyone help?
This means you can interact with its inputs/outputs by the following means:
Manually control it using the Demo application you mentioned;
Write your own application in a supported language (look for updated DLLs and code examples under “K8055/VM110: USB EXPERIMENT INTERFACE BOARD” in velleman.be/ot/en/download/files/);
Use a third-party software like ProfiLab Expert.
EDIT: Just to clarify, while making use of the product, you need to have it connected to your PC at all times (it’s not made to work stand-alone).
