Hi , i just getting a K8055 and i tried to creat a program in C with CodeBlocks, i linked K8055D_C.lib in project etc and added K8055D_C.h in the project
I wana see if it working by using OpenDevice(0) function and then use SetAllDigital() but nothing happend , my adresscard is “0” sk5 and sk6 are ON.
The version 2.0.0.1 of K8055D_C.DLL and K8055D.DLL are not compatible with Vista and newer operating systems.
Please see this thread for a solution: viewtopic.php?f=21&t=8505
Maybe you are using the Borland C++Builder K8055D.LIB for Microsoft C++ ?
The K8055D.LIB in the folder K8055DemoBCB is for Borland C++Builder only - it can’t be used with Microsoft C++.
You may use LoadLibrary and GetProcAddress to get sccess to the DLL functions.
Please see the main.cpp in the examples folder: K8055DemoDevC as an example.
[quote=“dragoncds”]Hi , i just getting a K8055 and i tried to creat a program in C with CodeBlocks, i linked K8055D_C.lib in project etc and added K8055D_C.h in the project
I wana see if it working by using OpenDevice(0) function and then use SetAllDigital() but nothing happend , my adresscard is “0” sk5 and sk6 are ON.[/quote]
Hi,I have met the similiar problem like yours. I wanna to know if you have worked it out.
Hope your answer.
Borland and Microsoft use different formats for their lib files. The one supplied by us is in Borland’s format.
If you have Visual Studio, you can create a lib file from the dll using one of Microsoft’s tools, it’s very easy. This website explains how: adrianhenke.wordpress.com/2008/1 … -from-dll/
I’d recommend you create the library file since it’s a good exercise, but if you don’t succeed in creating it, here are all the files: velleman.be/downloads/files/ … K8055D.zip
I have put the file K8055D.dll and K8055D.h under the project, then run the program and not found any grammer errors. Unfortunately I found the varible “h” is still keeping the value 0 no matter how I change the state of SK5 and SK6. By the way, I have been using the version of Visual studio 2010 and I have tested the chip by running the project named Demo and successed.
Hope the answer from you soon and thanks a lot!
[quote]Unfortunately I found the varible “h” is still keeping the value 0 no matter how I change the state of SK5 and SK6. [/quote]The new jumper setting is effective after disconnecting and reconnecting the USB cable
If still problems - as an alternative you may check the main.cpp in the folder \Examples\K8055DemoDevC.
This demo code shows how you can use C++ without using any .lib file.
Please use the latest K8055D.DLL from the package “Complete SDK Pack (Rev 4.0)” from: velleman.eu/support/download … 8055&type=
The older DLL versions may not work on new operating systems (Vista, Windows 7, 8, etc.)
[quote=“VEL255”][quote]Unfortunately I found the varible “h” is still keeping the value 0 no matter how I change the state of SK5 and SK6. [/quote]The new jumper setting is effective after disconnecting and reconnecting the USB cable
My teacher advice me to use the function named"LoadLibrary" and he help me getting start of the program.Now I can use the board to realize some simple function.
