K8055 Problem - LD8 Lit
The manual says LD4 should blink, then stay lit when the board is connected. I am having LD8 blinking then lit (no other action other than power). I can not get any response from the board at all via USB, and can not see any problems with assembly. Has anyone else experenced anything like this / is this normal?
TalkingJazz
After plugging the unit to the USB socket of the PC the LED LD8 should give three flashes and stay OFF. If it stays ON then the card is not detected by the PC.
You may find some help from these threads:
Please be sure that you have admin access during installation and running of your K8055.
