I’m new to PC interfacing.
I haven’t yet purchased this module.
If I measured a voltage through the AD channel, I understand it will display a decimal number: 0 to 255.
How would I turn this number into the actual voltage measured, so my PC displayed the voltage at the analog input?
Ive read the max. voltage that can being read is 5V.
If I wanted to measure higher voltages, the simplest way I can think of is to use a potential divider to attenuate the voltage to less than 5V then write code so the PC would display actual measured voltage.
What are your/better solutions to measuring voltages greater than 5V.
Connect the voltage to the analog input via a series resistor. This resistor forms a voltage divider with the resistor R3 or R4 and trimmer potentiometer RV1 or RV2.
Using a 99k series resistor you can measure voltage up to 10V.
An alternative approach to achieve the same effect is to change the resistors R3 and R4 to 100k.
Please see the circuit diagram on p. 21 of the manual: velleman.eu/downloads/0/illu … k_rev3.pdf
I would like to keep my actual P8055 board a lab-board. Is there a way to externalise the 15V adapter for testing and programming purposes ? I still don’t know if i will use this board or a 8061 for my application.
