Hello. I’ve got a problem with the USB experimental Board K8055. I need an outout voltage not from 10-5 V - I need 0 to 10 Volts. Is this possible if I change a resistor or something else.
Thank you very much for your help. Best regards, Matthias
This is not possible with K8055. K8061 features this option. With K8055 you need to add an external DC amplifier (e.g. x2 opamp) and external power supply.
